Discuss Worcester greenstar, Hot water intermittent. in the Gas Engineers Forum area at PlumbersForums.net
Ted808
Heating works and hot water- sometimes, but I noticed when I turn the hot tap on the pressure gauge drops to zero.
I've not seen this before. Topping up the pressure doesn't seem to make a difference. As soon as the heating only is on pressure goes back up to 1.5bar.
The thing is the flat is disgustingly filthy and I don't want to spend ages there... So if anyone has any pointers- much appreciated.
I'm thinking dirty line to PG and PV flat. Now can you get a blockage between the PG and the HW path only?
Check the diverter flap isn’t stuck
Check when hot water is running no flow is going down the htg flow
Other than the flow switch or plate it should work
Never need the guage go to zero on one tho then back to normal
Yeah I've never seen that either. Can't fathom it.
I can't think of a single-component cause but, if I've understood the OP's observations correctly and the pressure changes are relatively rapid, a combination of faulty expansion vessel and a PRV that is passing at 1.5 bar might fit the bill.
Reply to Worcester greenstar, Hot water intermittent. in the Gas Engineers Forum area at PlumbersForums.net
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Evening All, Been having on and off issues with a Greenstar CDI classic Combi were the hot water is not heating up but only intermittently. Some...
A
We have low hot water pressure in the entire house. Boiler is a Heatslave External 25/32, fuel in kerosene. The central heating is still working...
Abram R
A
Hi everyone, New here & my first post! I have a Worcester greenstar 24i, it is a conventional boiler, it has a water tank upstairs. For the...
2K
