Discuss Worcester junior 28i (non condense) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I said heat ex straight off mate. But I get the impression he doesn’t want Any part in it? As he says there is a load wrong with it.Just skim read this so may have missed something
The pressure rise will probably be a pinholed main heat ex (between mains cold and heating side) and the banging could be the prv chattering due to overpressure
Have changed a couple of older Worcester twin pipe heat exs and they aren't cheap
edit
by twin pipe, I mean separate waterways for heating and hot water (it;s actually 4 pipes) doh
You sure about that one Shaun C...??Just a good old decent service and replacement of the ex vessel and you will be good to go and you will be fine
And has valve
And dba???
Yep sure pal
Reply to Worcester junior 28i (non condense) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
