Discuss Worcester Negative Fan Pressure decrease after cleaning heat exchanger in the Gas Engineers Forum area at PlumbersForums.net
Hi, I am new gas safe registered. I serviced a old worcester R28 HE Z7-28 system Boiler. found negative fan pressure -3.95mb lower than MI's -4.2mb, Gas rate is 2.82 m3/h, little bit lower than MI'S 2.9M3/H, so clean heat exchanger very well. after that check fan negative pressure, -3.11mb, later check again-3.22mb working through 10minutes at Max Rate. Gas rate 2.61m3/h, just same as -10% of 2.9m3/h. Curiously, I check the heat exchanger again, totally clean, and wash through by 4 litre water, it is totally clean, never see any heat exchanger clean then this. I don't know why the pressure is lower after cleaning heat exchanger. Cheers
might be a weak fan taking into account boiler age & or check connections as through ageing can have leakage thus giving you issues.
Thats the problem with older boilers, wear & tear, if rest of readings check out then you will be fine,
cheers,
Andy
Reply to Worcester Negative Fan Pressure decrease after cleaning heat exchanger in the Gas Engineers Forum area at PlumbersForums.net
