Discuss Worcester oil boiler and water immersion heater question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Worcester Greenstar wall mounted Danesmoor oil fired condensing boiler and a separate water heater immersion cylinder (Range Tribune HE). Please can you tell me the following?My house uses electricity and domestic kerosene oil for energy:
- Can the water immersion heater be used on it's own for just water heating (with the Worcester boiler switched off) - or would the Worcester boiler need to be switched on for heating water?
- Can the water immersion heater be switched off and we just use the Worcester boiler for water heating?
- In the above 2 scenarios, which would generally be cheaper? or is it cheaper to run them both together for water heating?
- Would the water immersion heater need the oil fuel to function, or does it just use electricity for water heating?
Many thanks anyone who can help!
The Immersion is really just a back up so you can still have hot water
Some people use it in the summer
The immersion won't heat the heating
The immersion as Shaun said is just really a back up, should you need hot water and your oil boiler had failed or being replaced, etc.
That immersion element is near the bottom of the cylinder and would be very slow to heat the water and it would therefore keep using electric at a rate of 3 kilowatt per hour, which is very expensive.
Your oil boiler, in comparison, would heat your cylinder (even if cylinder was cold) in probably little more than an hour. The oil boiler would be cycling on and off during that period on its thermostat, so would not burn kerosine for entire period. A small oil boiler has a maximum output of approx 2 litre an hour (but that is a constant burn output), so obviously to heat your hot cylinder will be very low cost with oil
The hot water cylinder, not “immersion cylinder” is the large volume of water which is the hot water (when heated) that comes out of your taps. Now the immersion heater is the electrical way to heat the water (expensive way) but good to have the back up. And the oil boiler (the cheaper option) heats the water in the cylinder through a coil of pipe that is on the inside of the cylinder via heat transfer.
Reply to Worcester oil boiler and water immersion heater question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
After some advice, i have recently had solar panels fitted and have an Eddi which uses the energy we generate to heat the cylinder using the immersion heater. Just wondering if there are any devices that can circulate the hot water in the cylinder so the immersion heater heats all the water...
I have read of hot water cylinders being heated with a dual element immersion heater. The main principle being that a shorter element heats the top of the tank and then, subsequently, a longer element comes into play. With a bath/sink switch the longer element may be disabled. The topic of such...
K
We have a dual heating system, a solid fuel stove with back boiler and a external kerosene heater. The kerosene heater is working fine heating the radiators and the water for the taps The solid fuel stove will heat the water for the taps but the radiators will only get luke warm. Can anyone...
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each apartment for domestic hot water varies greatly in timing and volume. Thus the oil boiler is required to work for long periods which is uneconomical...
Hi, I have an unvented water heater which for some reason every year causes me issues. At the end of 2023 I noticed that the pressure valve gauge was going up when the water tank was switched on. My local plumber came and re-pressured the expansion vessel as it was flat, afterwards we tested...
