Discuss Worcs Bosch Greenstar 24i Junior. How do I adjust pressure guage? Constantly on red in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Lynn Passantino
Worcester Bosch Greenstar 24i Junior boiler. How do I adjust pressure guage - constantly on red.
Re: Worcs Bosch Greenstar 24i Junior. How do I adjust pressure guage? Constantly on
Hi, you need to supply some more info/background for people to help you.
Have you been filling the system from the filling loop, does the pressure vary, etc.
Reply to Worcs Bosch Greenstar 24i Junior. How do I adjust pressure guage? Constantly on red in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
