Discuss Wrong fitting or bad design? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Just mocking up what fittings to use for my shower valve to see that its not possible to fully fit an elbow to the hot inlet as it is fouled by the outlet boss.
I can fit a straight connection and elbow instead but just wondering if its actually the wrong fitting that ive picked? And its only designed for a straight connector?
No info in the crosswater instructions for this
No major issue but no such a great design since the outlet and inlet on the other side of the valve have sufficient clearance to use elbows
Has to be a straight male iron by the looks of it
Reply to Wrong fitting or bad design? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all! I'm in the process of fitting a replacement undersink water heater in my shed and, as advised in the instructions (yes, I know, what am I...
Just finished tiling and im fitting a wall hung geberit wc with a washlet which has its own water supply. The kit for the install comes with a 90...
Hi, I'm installing a water filter which has plastic inlet and outlet fittings like this... The suggested way is to go straight to flexible...
2K
Hello I want to replace the old single panel rad in the bedroom with a K2 double panel Stelrad one. I think I'm OK in general and relatively...
So, I went to this job yesterday to change over a faulty motorised valve on the hot water side of an unvented system. I drained the system, wired...
1K
