Discuss Yellow water from new unvented cylinder in the Gas Engineers Forum area at PlumbersForums.net
Has anyone experienced this before. Converted gravity hot water to new unvented cylinder (150l indirect evocyl) filled the cylinder up and had yellow water for about half an hour before it started to clear. Any ideas from anyone. I’m G3 registered. Was converted due to suspected split coil in vented cylinder
Yep clearing the muck out of the pipes as it’s old gravity I normally pipe them up straight from the mains temp and give everything a decent flush / run then pipe up to the cylinder
Reply to Yellow water from new unvented cylinder in the Gas Engineers Forum area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
