Discuss zero governor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A Venturi is nothing like a governor.
It is more like an injector in a gas cooker burner.
Pass gas or water through a restriction into a lower pressure area then there will be a negative pressure effect that will either entrain primary air into a burner or allow a diaphragm valve to lift.
Reply to zero governor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
