Discuss Should a plumber inform you that your new Combi boiler would be no good with a digital pump. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi. I recently had a renovation done. My builder installed a new Combi boiler instead of my system boiler. He connected the pipework to the digital pump. He did not inform us that we would need a new processor because we had changed to a Combi and subsequently a valve blew. Should my builders plumber informed us before doing the work. It has cost me £500 for Aqualist to install a new processor
He should of made you aware of you had any shower pumps or digital then these would need to be upgraded / replaced
Can I ask how many bathrooms you have as combi boilers are only really for one outlet at a time where as a cylinder you could do a couple depending on you tank etc
Hi.
I only have one bathroom. I recently moved to a bungalow and was seriously in need of storage. So I opted for a Combi boiler so we could make use of the cylinder cupboard and the extra loft space.
That’s perfect then 👍
Reply to Should a plumber inform you that your new Combi boiler would be no good with a digital pump. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello, We had an extension built seven years ago. Initially the builders' plumber connected the heating to the house system but this didn't work...
My son moved to a new build home in Cornwall last November. Yesterday evening he found a quantity of water beneath the Ideal Combi boiler and a...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater...
