Discuss I wish to add a second boiler to my existing meter. Location 20m away. in the Gas Engineers Forum area at PlumbersForums.net
UK
I wish to add a second boiler to my existing meter. Location 20m away. Underground run. Can l use 32mm yellow pipe with copper tails at each end. Thank you in advance
What size are your existing and proposed boilers kw
Hi Shaun. Thank you for the reply. Both 9kw. Will the meter be able to supply that volume of gas....
So heat only boiler in theory yes you should be fine providing the gas safe engineer works out there pipesizing etc
It's a 6m3/h meter Shaun will that cope with 18kw.... Is there any reason l can't use 35mm plastic yellow gas pipe after the meter under the ground. Thank you. Matt
Yes stnd domestic meter
The gas engineer can but it’s a bit more labour in installing it as it needs special fittings and practices to terminate above ground
Reply to I wish to add a second boiler to my existing meter. Location 20m away. in the Gas Engineers Forum area at PlumbersForums.net
I have a domestic gas meter located at one side of my building and my boiler/cooker (only 2 gas devices) on the other side of the building. There...
3K
I have a open flue old boiler (natural draft for combustion) installed on outside wall. Before winters want to install a heat only condensing...
I'm planning to get an air source heat pump (ASHP) installed and I'm considering my options about the location of the water cylinder as I live in...
2K
I've had a burst pipe under bathroom floor. Ive had it dug up and made safe with the affected pipe cut and end caps fitted. The pipes are cover...
