Discuss 1/2” BSP SENSOR POCKET ASSEMBLY LONG leaking in the USA area at PlumbersForums.net
Hi all
I have a leak from the 1/2” BSP Sensor Pocket Assembly Long of a Megaflo Eco SystemFit Unvented Cylinder.
Any ideas on how to fix it?
regards
Jim
how old is the cylinder?
tbh i would phone megaflow up as it should be still under warranty
Had the same issue with a Electra stream the cylinder needed draining and replacing with a new 1/2" pocket . Kop
Reply to 1/2” BSP SENSOR POCKET ASSEMBLY LONG leaking in the USA area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
