Discuss 1 inch of water lying in the top compartment of a Worcester Greenstar 28i junior in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone ever came across about an inch of water lying in the top compartment of a Worcester greenstar 28i junior. Was wondering if anyone knows the possible cause? Thanks.
Have you found it?? If so are you gas safe?? If not you shouldn’t have the cover off. Please get a gas safe engineer out as the case forms a combustion seal protecting you and your family from any nastys the boiler could kick out
The gas Safe police will be about soon enough to ask if you are gas Safe as you need to be to take the front cover of your boiler off.
And like a flash of lightning I couldn't even finish my sentence.
Harvest. Indeed.
Should I use my powers of invisibility for good or evil ?
Closing till OP confirms quals or not
Reply to 1 inch of water lying in the top compartment of a Worcester Greenstar 28i junior in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
