Discuss Kerosine or light oil in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
what do you guys set your anaylser at when servicing an oil domestic boiler?
I know the print out on Testo states CO2 max possible (theoretical) with kerosine is 15.4 %
So I must be set to kerosine.
I hope I am on correct setting. o_O
It does what it says on the tin.
I was renting it from heating world of spares which included calibration.
It's now mine and calibration is due in a month, son hopefully not too much.
Paraffin and 28sec kero are much the same. What we in the U.K. know as Paraffin (dum dum dum dum....Esso Blue) is just more refined than heating kero and is better suited for indoor appliances like Tilley Lamps and greenhouse heaters as it smokes less, but chemically it’s the same stuff.
35sec diesel is light oil - sometimes called gas-oil or Marine gas-oil (MGO). Intermediate fuel oil (IFO) is a medium weight oil (like engine oil). Heavy fuel oil (HFO) is ‘orrible thick industrial stuff than needs to be pre-heated.
Some analysers don’t discriminate between ‘Kero’ and ‘Light Oil’ as there’s not much difference in the figures produced.
Reply to Kerosine or light oil in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, we have Worcester Bosch heatslave external oil boiler 18/25 Boiler locked out. Pressure was below 0.5 so brought pressure back up. When lock...
When I set it to be on via phone, light A comes on (telling it to be on), but light B won’t come on, so the boiler doesn’t start. I either need to...
Hi Oil experts. I had a grant wall boiler with a failed transformer. Carried out a service and pretty sooty nozzle, and baffles build up suggest...
Firstly I won't be touching or going anything... I only want advice if this is right.. my partners dad has a aga that is solid fuel unregulated...
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered...
