sheff paul
fitting over flows from a break tank boosted cold water. can you get a water less trap bladder type to go inline with terrain solvent
Discuss 110 mm water less trap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
what size mate ? as if 110mm thats one big arse tank
Having to direct it to a existing rain water 110 mm pipe,as its in a cellar with no floor drain,hence it has to be trapped to stop any smells ,no size data on the break tank,but at least 3000 litres
What's your inlet pipe size?
That is an odd size 90mm, hope it's a female iron
https://www.plastics Thanks Sha...tem we could find on line,we shall go with it
https://www.plastics Thanks Sha... when it's overflowing so had to fit an alarm
It's the same as long as it's got a spring return else you won't be able to have any fall on it fitted a few tbh it's the only way you can get round it, but the problem I found is they can't tell when it's overflowing so had to fit an alarm
From Water Regs point of view I would say that you couldn't rely on the 110mm anti flood drain valve for back flow protection from the RW.
It Is not tested & not approved to prevent rain water which would be cat 5 from entering the basement & then the cisterns if the rain water system surcharged or blocked & then filled the basement.
I would recommend treating it as a below ground cistern installation & use a sump pump with the alarms to give warning of overflow / pump failure.
I know it is the costly option Paul but if this is cat 1 drinking water chance are someone may look at it.
It's rated for flood water so would think it would be ok
OK for flood water exerting a house Shaun but it is still a mechanical device (single check) stopping category 5 water from back flowing into category 1 in the boosted cold water cistern albeit via the warning & overflow pipework.
But the difference is in this cellar the risk is that the whole room could quickly fill with water, jump the air gaps back flow up the overflows & pollute the drinking water systems.
Not likely in other areas, at the end of the day it is assessment of the risk, if in doubt phone WRAS they are normal very helpful.
Reply to 110 mm water less trap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
