Discuss 135 y branch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When using a 135 y branch is there an offset that can bring you back to square from the branch? A standard 45 degree offset isn't enough.
It should take it back to square. Mustn't be the angle you think. Take a look at the degrees the fitting or tee say they are.
A 135 and a 45 will take you square, I guarantee it. Unless you have twisted either of the fittings if that makes sense?
Reply to 135 y branch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
