Discuss 15/22mm cold feed to boiler in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
I'm in a house with the cold feed coming up in the kitchen. In 25mm mdpe. The boiler is in the garage adjacent. I plan on running the cold from the sink in the kitchen under the kitchen units to the garage to feed to boiler. And the 15mm coming back from the boiler to the sink. Would there be an advantage of taking the cold in 22mm to the garage to where is splits to feed the boiler/ the rest of the house?
The kitchen sink and washing machine getting feed before the pipe goes to the boiler but that would be all. Then a bathroom to feed, 2 ensuites and a cloak room.
If you have a 25mm main you're laughing really. Run 22mm from the stopcock, then tee off in 15 from the 22 to the sink, another to the shower/bath, another to the toilets/basin and then 15mm to the boiler. It will be massively overkill but it will help prevent reduction in flow when showering and something else consumes water too
25mm main I need to tee of to the sink yes. Then it's one pipe under the kitchen plyth that goes to feed the boiler in the garages and then after teeing off to the boiler feeds the rest of the house.
Reply to 15/22mm cold feed to boiler in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and...
1K
I have a badly blocked feed pipe to kitchen rad, was running very slowly but I’ve made it much worse trying to clear blockage with curtain wire...
Where and how does the water supply work and is there only one rising main pipe and where is it usually located? I am top floor flat, mains fed...
Hello, I have just installed a vented McDonald 250L thermal store, it is for multi fuel but currently just connected to a standard oil boiler in...
1K
Hi there, All was good until one day the hot water suddenly started running quite a lot cooler. Putting my hand on the output at the boiler it's...
