Discuss 15mm to 1/2" BSP Male Flexible Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Is there such thing as a flexible braided hose that will go from 15mm pipe (plastic in this case) to 1/2" male thread? If so, where would I get some as I've not seen them anywhere.
I have some bath wall valves that have female 1/2" BSP threads for the input and output flow. I was hoping to limit the connectors as they will be mounted in the walls behind tiles.
Thanks,
Daz
Thanks,
Daz
when ever possible i would use soldered m/i's on showersand taps in walls
What's an m/i?
If I use a soldered joint then I am adding another connection. I was trying to reduce the amount of connections down to a minimum.
I have to have something to screw in to the female 1/2" thread. Instead of using a 1/2" male to compression / pushfit / soldered I was thinking a flexible connection that just screwed into the female thread would be better. (It's in a partition wall incidentally).
you can get them from toolstation but not skrufix i believe.
in fact i have a couple in the van.
Manufactures instructions:rolleyes: He was refering to a male iron
my mistake just had a look and they must have come from merchant.
if you get 2x 15mm comp ends and take of nut, isn't that the same?.
I don't think you can do that. I am sure 1/2" BSP male threads are usually bevelled so that they create a water tight joint to the female parallel thread.
Am I correct?
Am I correct?
i shouldnt think so,
pack it with a douzen wraps of ptfe, same thing!.
I think you are getting confused with BSPT (The T stands for Taper)
A 15mm compression fitting with BSP threads and nuts removed will go into the tap end of a flexi tap conenctor to make a male end.
I took my wall valve and asked the question last night at a plumbing course I'm on and he said removing a nut off a 15mm compression joint or pipe and screwing it into the valve would definitely produce a leaky connection, (even the PTFE tape wouldn't help). He said it's the same type of thread as the radiator valves (top valves, bleed valve)
The plumber at B&Q told me the same as well, (not that B&Q advice makes it any more reliable lol!).
It does make sense though as if there was no difference then you may as well just buy a 15mm compression coupler and remove the nut rather than buy a 15mm compression to male 1/2 BSP.
It is very confusing all these different types and I didn't realise that there was BSPP and BSPT!
I think I may look at the pushfit to 1/2 BSP male connectors and connect up this way. Mind you I am still a bit confused as to whether it needs to be a BSPP or BSPT type. Hmm can you tell be looking at the thread?
Thanks all,
Daz
Seems like for every answer I get I have two more questions :)
Hmm!
Its a bit hard to tell a taper from a parallel thread.
But a taper is designed to go into the likes of mild steel sockets, tightening onto the walls of the socket the more you screw it in.
But if you use a taper on soft metals such as brass the chances are, as you tighten it it will split the softer metal socket.
I have found, your usually okay fitting a parallel thread in a taper socket though, providing the socket is deep enough and engages enough of the parallel thread at the bottom of the socket.
Another problem you may find with taper threads, is that on parallel thread sockets they only go in a few turns and leave you wondering whether those few threads are enough.
Anyway I think most sockets on a shower have parallel threads, but I might be wrong.
But using the right thread in the right socket is the answer.
Doesn't the manufacturers info tell you? Unfortunately BSPT it seems can mean either British Standard Pipe Thread or British Standard Pipe Taper.
If its taper it usually tells you somewhere.
Reply to 15mm to 1/2" BSP Male Flexible Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
