Discuss 2 Meters Convert to 1 Smart Meter in the Central Heating Forum area at PlumbersForums.net
Currently We have 2 meters and each meter is connected to 2 CU. We are looking to upgrade to a smart meter. At the moment OVO have no slots for my area however, when I do get a slot they will replace 1 of the meters and remove the other they bit I'm not sure about is how will the 2nd CU connect into the smart meter? Will I need to get an electrician to daisy chain the 2 CU from the smart meter?
Below is a picture of my setup. The Top CU is for Lights and sockets. The Bottom CU is for the dry heaters and water heater.
Sounds like your on eco 7 eg cheep night elec for the heaters and water cylinder?
Reply to 2 Meters Convert to 1 Smart Meter in the Central Heating Forum area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Sonya K
