Discuss 22mm speedfit to waste pipe??? in the USA area at PlumbersForums.net
I'm installing a waste pump in wet zone area(ground floor concrete) Waste pump has 22mm feeds which I would normally connect to soil pipe with boss strap. However the soil pipe is clay embedded in concrete with a 90° pan connector going straight into the ground. I've seen the pan conns with waste outlet in 1 1/4 I just need to know if there's any adapters to go from 22mm speedfit into waste pipe????
It's one of these with that connection hows overflow pipe going to be compatable?just don't want it to leak obviously.
Reply to 22mm speedfit to waste pipe??? in the USA area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
