Discuss 3 hole basin tap shroud. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Gents,
I've been asked to repair a tap. It's part of a three hole basin tap.
The tap handle comes off nice and easily but I cannot access the tap body nut because of a very tight fitting shroud that prevents any box spanner fitting onto it.
I have tried to ease the shroud off but it is fixed solidly.
The back nut under the tap is nicely hidden, very thin and I can't get to it because the elbow that connects to the spout hinders any access.
Is there a propriety tool or do I have to strip the whole tap out part by part?
To make things even more interesting both the hot and cold cwsc gate valves seized shut
:disappointed:.
So, I'm not too impressed!
Any help is appreciated,
TerryH
Reply to 3 hole basin tap shroud. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Hi, I am trying to fit a replacement tap to a mini-sink that's built in to the top of a toilet. The original tap isn't made any more by the...
Please can you help. I’m trying to replace the cartridge on our monobloc kitchen mixer tap. I’ve found the secret hexnut and removed the handle...
4K
Hi All Looking to replace taps on a cast iron bath, accessing them is near impossible (i even had to remove toilet). The taps are old lifter type...
4K
Hi, recently moved into new house, (the house is four years old), the bath has very low hot water temperature, I'm assuming its an anti scald...
2K
I wonder if anyone can help, I've tried several plumbers merchants to no avail. I have removed an old stopcock, (which seized long ago, with a...
2K
