- Messages
- 1,877
Before you do that, check the voltage across the gas valve when the fault occurs. If it's low, i.e not 230V, the GV is faulty.Gonna go fit a Drayton later an see what happens.
Discuss 3 port keeping the heating on? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
May have the answer now.
Biasi were really helpful. Turns out most 3 port valves have this problem. It's apparently the way they work.
Biasi said do one of 2 things. Either fit a Drayton as the residual voltage is below 60 so they say or fit a capasitor of 0.47 microfara across the switch live and neutral to take the voltage away.
I have used a capacitor in the past to soak away the stray voltage. First time I came acriss it was when one was supplied wuth a new pcb for a glow worm micron which explained that its job was to deal with stray voltage from 3 ports. Not needed on s plan.You can get a resistor/relay whatever you call it from Worcester (I think I have posted part no before) that goes between SL and N to counteract this, as I have has Worcester PCB's chattering due to this stray voltage
Reply to 3 port keeping the heating on? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
