Discuss 3 way valve replacement in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi I'm going to replace the 3 way vale on my open heating system. Hoping someone can advise.
In the picture, to isolate the valve I am going to turn off 1, 2 & 3. However as you can see I can't turn anything off between the valve and the hot water tank. If I use a bung in the header tank, will the water from the tank be a small amount? Are we talking just drips or will it be the conents of the top half of the tank?
Appreciate any advice, thanks Paul
Reply to 3 way valve replacement in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
PSxxxxxx
Sonya K
