Discuss 32mm minimum size for external condensate - rule came in when? in the Central Heating Forum area at PlumbersForums.net
Ric2013
Hi. Was looking for a house on sale the other day and just wanted something confirmed to me...
Was there ever a time when a condensing boiler could have been legally fitted, and in accordance with MIs, with a 22mm overflow used as an external condensate pipe... and with that condensate pipe discharging to ground (not to a lime filled soakaway 600mm from the wall, but literally onto the ground)? Given the respective radiator and room sizes, I doubt that boiler will ever run in condensing mode, but all the same?
I commented that it wasn't entirely right. I appreciate it's not a big deal in the scheme of things and could be remedied fairly easily, but I'm just interested to know if my opinion is correct that that probably was a semi-cowboy installation I was looking at.
2018 for insulation and 2016 for bigger than overflow recommend exterior
Never always has to be drain or soak
Cheers for that one, Shaun.
Just one more quick question. The balanced flue (condensing gas boiler) has foil tape over a couple of the joints internal to the building. It's been applied very neatly. Should I assume the joints are at fault, or could it be that a gas installer (the fitter, or one inspecting at a later date) has simply applied it as a further layer of protection? I haven't bought the house, but am seriously thinking about making an offer and am trying at this stage to work out what sort of likely condition it is in.
I would want to inspect them joints could be incessant but could be hiding a flue leak
It's one of them places...
Comedy gold was when, since the basement room is below drains level, I flushed the toilet to see if there was a Saniflo and if it was at least roughly working. The Saniflo was working... but the toilet fill valve decided it was fed up with life and wouldn't shut off the water. Estate agent was quite pleased when I offered to get a screwdriver from the van and isolate the fill valve for him.
Reply to 32mm minimum size for external condensate - rule came in when? in the Central Heating Forum area at PlumbersForums.net
I have a CH boiler installation with a nice simple vertical condensate drain, down and out through the wall to a pipe outside. All is as it should be but I'm fitting an upgraded external pipe setup to include insulation. The inner 22mm pipe mates with the 32mm pipe just inside the house. It...
Hello, I have a rental property and had a new combi boiler fitted 2 years ago. No problems at all with the boiler, my only niggle is that the external condensate pipe is 32mm and fully covered with black insulation. This pipe runs almost 3 metres across the outside wall of the kitchen and then...
16K
I have had some helpful comments elsewhere on how to minimise the chances of the condensate freezing in an external pipe so thanks to all. Trace heating is probably going to be too expensive but I am considering a pump though it doesn't help get to a point internally because of layout. Because...
2K
M
  • Locked
Hi there, The 21 year old boiler (Worcester Bosch 350) has failed in my first floor, small one bedroom flat which has concrete floors throughout. My existing boiler is in a cupboard at the back of my lounge next to an outside wall. The flow and return pipes come out here too (I think they run...
4K
munchkin19
M
  • Locked
If having to have the condensate discharge externally, Is 32mm 1.25inc or 1.5 inch 40mm waste pipe best? The instruction say a minimum of 32mm.
2K
