Discuss External condensate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If having to have the condensate discharge externally, Is 32mm 1.25inc or 1.5 inch 40mm waste pipe best? The instruction say a minimum of 32mm.
bigger always best but depending on length of run i wouldn't want to go really over 3m unless frost protection is present
Just extra hassle and a bit overkill IMO, expensive as well!
what armaflex just a tad more than normal (thick) round here about £10 + the dreaded for a 3m length
Seen one in 15mm speedfit yesterday :( I normally use 32mm with black lagging.
location also to be taken in to consideration 3m on a flank wall 10m up will be more likley to freeze than a metre in the corner next to the kitchen door
Reply to External condensate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
