Discuss 35cdi extra in the Plumbing Jobs | The Job-board area at PlumbersForums.net
smhstu
Hi all
any help/pointers on this.
hot water demand, after approx 5-10 mins boiler bangs like a good en and steam blows out of aav
changed both thermistors, still the same.
sludge remover added, still the same.
im thinking the PCB not reading thermistors
any clues?
Will remove plate and descale tomorrow, hope that works.
not in a hard water area
thanks
Construction debris in system. Had a duo chocked with poly balls and fiberglass
My m8 boiler did exactly the same, gave up some strange error codes as well. Plate hex blocked.
Reply to 35cdi extra in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Current setup: Cold water tank, and header tank in loft. Hot water tank in airing cupboard at top of stairs. Power shower (mira event xs) in main...
2K
Hi hoping someone can help with this as its beginning to drive me nuts. Boiler generally well serviced and working fine, no problems with DHW...
About 10 months I started having issues with a gas like smell in my home and the gas board was unable to find any gas leak I've still got the...
Hi, I have purchased a new build property, which has a family bathroom, cloakroom and 2 en-suite shower rooms. All 4 basins have push button...
1K
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
