Discuss 6m pump only going to 4m max setting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Best
Subscribed
Wondering if I have a faulty pump?
On variable speed or fixed speed settings it will only go to 4m.
If I set it to max variable, 6m flashes and then goes to 4m
is it auto adjusting to a restriction ? eg getting too much back pressure so its knocking it self down ?
That was my thoughts, but on fixed speeds, at C3 max setting, it still only goes to 4m.
The system is a bit suspect of blockage and that was the reason I replaced the original pump.
I would have thought it should be 6m, regardless of any system issues.
I had no time to do anything else.
There is a bypass valve might be worth opening fully to test if pump changes
i would open it worth a test
what pump is it?
It is identical to this pump, only goes under different brand names.
https://www.NoLinkingToThis/p/flomasta-central-heating-circulating-pump-230v/45357
Reply to 6m pump only going to 4m max setting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
