Discuss 6mm Hardibacker over skimmed dot n dab in the USA area at PlumbersForums.net
Existing bathroom has skimmed plasterboard dot and dabbed to block wall. The chosen tiles are over the safe load limit so thought about screwing 6mm hardibacker to the walls first then tiling onto this, anyone done this, see any problems with this or got an alternative etc ?
I thank yarr in advance....
All done to the amount and quality of the dabs , we have all tried to remove them and know what a PIA they are .If the size of the bathroom will stand it you could batton the walls with some “ slaters lats “ and screw the boards to the lats .
To tight to fit batten and boards unfortunately. My logic was that you can hang a 2000 x 600 double rad on a dot n dab wall so surly, if screwed correctly, it should withstand upto the weight limit stated by backer board?
Obviously I'm not thinking I know the answer already, just stating my reason but will obviously listen to anyone who has or new about this
I've seen the info they have and those vids but it doesn't state about skimmed plaster board that is still dot and dabbled to the wall, whether i can screw hardibacker on the face of this... 🤔
glue and screw as in vid just use longer screws
Reply to 6mm Hardibacker over skimmed dot n dab in the USA area at PlumbersForums.net
Hi there, I'm having a bathroom remodel. It would be appreciated to get some expert advice. Plumber ripped out existing bathroom and most of the...
4K
First - an apology for monopolising the forum with all my plumbing questions! I'm hoping this will be my last and I'll move onto something else...
2K
We live in a terraced row (SW London) and our neighbours are currently in the process of finalising their extension. There is a potential...
2K
Hi all - apologies in advance for the essay. Posted a week or two ago about a botched shower job and had some really helpful replies (tray...
7K
Hi All, Hope you and your families are well. Our boiler in the family home is on its last legs. Our family home: Has a Halstead Iheat 35c. It...
2K
