Discuss 790MM RADIATOR - CAN I PUT ON A 800 TOWEL RADIATOR? in the USA area at PlumbersForums.net
HI ALL, WE'VE A 790MM RAD IN BATHROOM.
I WANT TO PUT ON A NEW TOWEL RADIATOR
THE PIPEWORK IS FROM THE GROUND AND IS PVC/FLEXIBLE
CAN I PUT ON AN 800MM TOWEL RAD?
IM ONLY ASKING BECAUSE I CANT SOURCE A DECENT HEIGHT 790MM IN GREY TOWEL RAD.
THANKS
Yes should be fine you might have to lower the rad 10mm to get the extra length on the pipework but should be doable easily
Reply to 790MM RADIATOR - CAN I PUT ON A 800 TOWEL RADIATOR? in the USA area at PlumbersForums.net
Hi all I need to run this CH pipework to a radiator located beyond the electric wiring in the image below. Just to be safe I was wondering if...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
