Discuss 8 male and 10 male tale pipes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
joe brown
how can you tell if your pipes ten male or 8 male, i have a mono mixer and need to get flexi pipes for it but they come in 8 male and ten male, what does this mean, anny advice greatful, cheers in advance
10 Millimetre or 8 Millimetre thread size. It's Mil for short, not male. And 10 is bigger than 8. If you get both sizes from a merchants, they should let you take the unused ones back.
of course you can come across m12 threads too.
take the tap down the merchants!
Buy both. They're a few quid per pair (online) and you'll use the other one before long. It's best to have both on you, mostly it seems to be 8 though. They go down quicker in my flexi bag.
in the uk its normally m10 for basin and m12 for sink. Like watertight has said its always best to have diffrent sizes on the van, saves a trip to the merchant.
yeah actually i meant 10 goes down quicker. i was thinking i keep 10's and 8's cos that's what he mentioned. i actually keep 12's and 10's.
Reply to 8 male and 10 male tale pipes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good morning. I've purchased a Brondel Bidet seat (basic,non-electric) and fitted it to my UK close-coupled toilet. I knew it would come with US...
A
Hi, I am trying to fit a replacement tap to a mini-sink that's built in to the top of a toilet. The original tap isn't made any more by the...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
Need some advice, neighbors sewer drain keeps blocking up every few months. My wife and I have always chipped in with the other three neighbors...
