Discuss Compression fitting loose on the pipe in the DIY Plumbing Forum area at PlumbersForums.net
A
Alex_nv
I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi.
The problem is that the old pipe seems to be slightly smaller than 22 mm compression fitting and when I tighten the compression nut the whole fitting is easily sliding off the pipe and does not hold water.
I tried to put the PTFE tape at the end of the pipe in order to make it bigger/thicker. It worked to some extend but there is still a very small leak.
I am not sure what would be the best next step.
  • Just try to tighten the compression nut even more. It is already very tight and I heard that overdoing the nut can damage the pipe.
  • Or take it all apart and try to put more PTFE tape in order to make the pipe thicker.
What would a professional plumber do?
Anybody come across this situation and have any advice?
Thanks in advance!
Reply to Compression fitting loose on the pipe in the DIY Plumbing Forum area at PlumbersForums.net
