Discuss A boiler question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I did a similar thing few months ago. Bleeded the radiators (after watching a youtube video) without thinking twice about the boiler. Boiler went to lock out mode, had to call an electrician who had to reset it and get the pressure level up.
You may need to check where your water connection to the boiler is and open it slightly so the pressure can increase within the limits. If its too low, reset wont work. But adjust the water slightly as the pressure goes up quickly when water flows. You may need two people - one to adjust the water flow and other to shout when the pressure starts to increase. Also please read a lot about your boiler before you do any of this.
I am still suffering the consequence and now having to install a new boiler altogether. alll because i bled the radiator stupidly without thinking of the boiler.
Or, hows this for a novel idea, get somebody who knows what they are doing!
if you need a new boiler just for letting the water pressure drop someone is pulling your leg
Reply to A boiler question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
