Discuss A Leak But No Water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
V
Veggie Dave
Okay, what am I missing?
I have a customer with a water bill that's far higher than it should be given there are only two people in the house.
The water meter keeps turning, albeit very, very slowly, when nothing and no-one is using water.
If I isolate the customer side of the meter using the stopcock immediately after the meter the dials stop moving.
If I isolate all the brass ware and machines on the system the water dial still moves.
There isn't a single, solitary sign of a leak anywhere.
The vast majority of the system is visible, there's only a vertical run of around three feet that's boxed-in, but there's no sign of water at the bottom of this boxing.
I would swear blind there's no leak anywhere in the system, yet those meter dials keep moving. Theoretically there must be a leak but there isn't a single drop of water anywhere. :banghead:
its leaking some where, you just need to find out where, just check the roof tanks arent filling when your looking for a leak, common error. can you isolate incoming main and then check dial to see if leak on supply to house.
Not a wc with a built in overflow?
Aaarrgggghhhhh! That was the one thing I didn't check. There was no obvious flow into the bowl but I forgot to actually check the cistern itself.
It's a combi system, the pipework to the tanks in the loft have all been removed.
Sadly not, which is why I had to physically isolate and check everything connected to the system.
WC is my bet if you can see all the pipe work.
She's just looked and, apparently, it's not over flowing. This was by text so I'm going to talk her through it on the phone as this seems to be the only possible cause left - if there's no problem there then I may have to give up and become a tiler instead...
There isn't a T in there going to somewhere, next door, outside tap or?
Alternately can you cut the pipe after the meter and before any T and cap it, it may be a dodgy meter?
u seem to be missing the fact it may be leaking on the underground section to the house
There's definitely nothing going either outside or to next door. It's impossible to say there's definitely not a fitting hidden somewhere on the pipe run that's boxed in, but there's no logical reason for there to be one nor any sign of water along the only possible run there could be.
As I said, the entire system, barring the three feet of boxed-in pipework, is visible. There is no underground section after the meter.
Reply to A Leak But No Water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
Suddenly my downstairs toilet stopped filling this week, I suspected a blockage in the filter or cistern itself, however after removal of...
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also...
