Discuss A rad is a rad? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
smudger
Hi Folks. Opinions please. Been asked to supply some rads for a customer, prices quoted by my usual plumbing supplier are well above prices from e.g Toolstation. Do all rads of the same spec (size etc) throw out the same amount of heat? Or is it worth spending the extra cash?
Thanks in advance for your input
Check the datasheets from the manufacturers, there might not be much in it but there usually are differences. Be careful of really cheap ones as the steel is very thin and pinholes easily.
What type of standard rad throws out most heat for the specified BTU?
I had customer who supplied his own Turkish made rads, they were terrible, weighed 3 times as much as an equivalent Stelrad and kicked out half as much heat. Be careful!
Almost all rads sold here have there heat outputs (& its Watts not btu's boys) displayed after being tested to BS EN 442 (i.e. Delta T 50) so that you can compare like for like on outputs but it is worth a check cos a few use Delta T of 60 deg C not 50, look for the BS 442.
Just had a look at some Stelrads and a double convector looks like the job.. Can't go wrong with them then, would you say?
They all give off what is specified.
The difference in output per size between the best and worst performing brands is only about 5%
stelrad,quinn,myson, etc.... all decent rads. Go for the one your local merchant give the best price on.
Excellent advice from everyone there. Really helpful, Have a good day everyone. Hope to speak to you again soon.
Thanks again:euro:
A large number of rad brands sold in this country are made in Turkey. Some are fine, some are OK, and some are terrible.
As others have said, check the EN442 outputs, and make sure that they are at DT50 (which they should be if from a reputable source).
Reply to A rad is a rad? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
  • Locked
Hi Everyone, I'm looking for a little advice so I can try and save a bit of money this winter (especially considering the new prices!) I have an...
Hi Everyone, (not sure if my last post worked so apologies if this is a duplicate). I have an Ideal Boiler (vogue max system 18) and a MegaFlo...
Current setup: Cold water tank, and header tank in loft. Hot water tank in airing cupboard at top of stairs. Power shower (mira event xs) in main...
2K
Interested on thoughts on this (I've also posted on another forum but thought this might be a better place to ask); Long time lurker, have...
4K
Good day all, I would like to get some advise and perhaps the solution to the issues with my UFH system. We did install UFH in an entire house...
5K
