Discuss A strange dripping tap problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Used to try and do it without reseating washer (seems like a lifetime ago) but too many hassles. So every one gets reseated now.
Once in a blue moon you'll get away with it, but for the sake of 2 minutes with a reseating tool.........
I still don't understand why and how I have to turn off one tap to stop the other one dripping. To try and find out was the reason I posted (and my friend has the same problem too).
What may be happening is when you open your hot tap you take pressure off the cold thus allowing the cold to sit properly,if you do as said above you may cure the problem
I don't know how ceramic/qtr turn taps work. I understood when they first came out that they never needed rewashering but a friend had a pair on bathroom sink and one was always dripping badly (she was not on a meter so did nothing about it).
I must google to see how they work.
WOULD YOU RECOMMEND THEM?
Reply to A strange dripping tap problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Bristan Manhattan mixer tap in the kitchen. Five years ago, it started to drip. I replaced the valve in the cold water side and the...
I have a kitchen mixer tap with quarter turn levers and the cold side started dripping. I took out the ceramic valve and replaced it with one from...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
This is probably obvious but I want to replace the cartridge to stop dripping. I have done similar before but I cannot work out how to remove the...
I have been trying to turn off my outside tap for winter. When I turn the valve under the kitchen sink, it fails to stop the outside tap from...
