Discuss Aav in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DaveG
Hi.
Could someone tell me how to remove the AAV on a Vaillant ecoMAX 828/2 E pls?
Many thanks
Using your skilz!
Check the manual, they usually have it listed in the back.
Thanks. Any tips on correct tool to use to remove it. Seems to be a very narrow gap for a spanner.
you call that narrow??????????????????????? try working on a worcester theres loads of room there
A spanner is too thick to get under the housing. Do you use a specialised tool?
Would you just use the grips on the housing itself. There appears to be a nut underneath but cant get in there.
Reply to Aav in the Plumbing Jobs | The Job-board area at PlumbersForums.net
