Discuss Accumulator query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Riley
Super Moderator
S. Mod
Subscribed
Evening.
Apologies if this is an obvious question but do you need to hold G3 to fit accumulators??
i know it's pressurised but not in the same way as say an unvented.
Cheers
matt
Doubt it mate. It just a big expansion vessel innit. The problem with unvented cylinders is if the stat fails and water is boiling,, as soon as someone opens up a tap and releases the pressure the water turns into steam and creates a bomb. Think its 1600 X the amount it was when from water to steam. Accumulator is just cold water
That was my logic but just wanted to be sure. Cheers mate
As has been said, you don't need G3 to fit accumulators.
That shouldn't be a problem excess pressure discharged via pressure relief valves before it gets to dangerous levels.
Reply to Accumulator query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Hello, I'd love some advice on my system, I've had a couple of plumbers come in that seemed to specialise in gas systems and seemed perplexed by...
Hi, I was hoping to replace an old system boiler with a Vaillant Ecotec Exclusive 627 system boiler, thats the one with the diverter valve so no...
Hi all, this might have been asked many times before, so apologies. Just moved into a new housebuild and the bathroom tiling is not good! What...
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I...
