Currently reading:
Adaptor required for angle grinder disc
Discuss Adaptor required for angle grinder disc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Phil
I've got a toilet to swap over in a bathroom and need to clean the inside of the cast iron soil pipe to accept a Mulitiquick.
It has the usual 80 years of corrosion/scale build up and want to grind that off pretty quick to a smooth surface for the fins to seal against. I'll be against the clock on this and need a fast way of doing it.
ae235
I want to mount one of these into my core drill and grind away at speed but I need to find an adaptor to fit into a keyed chuck.
Or is there a better method?
Clean + Strip disc will take off paint and rust back to bare metal. They don't clog up like some wheels. 3M do the original best quality one. Needs a seperate arbour to fit into drill or Screwfix do a budget version with arbour moulded into disk. Item ref 72889 in my old spring catalogue.
Sent from my BlackBerry 9800 using Tapatalk
Reply to Adaptor required for angle grinder disc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
