Discuss adding a extra radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
micky
Ive connected a extra radiator with 15 mm pipes to the 22m flow and return pipes the water starts to go down to the radiator but dos'nt seem to return.is there a limit to how far the radiator is from the flow pipes.
close the other rads,see if it flows through new rad,if so maybe air lock moved or rads require balancing ,with in reason distance should not be an issue if only one rad on system,used to drop down from ff flats to entrance hall rad below,once set p,operation Ok but first to play up if a problem
Reply to adding a extra radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
Hello folks I've moved into a property last month and started to note things that may need looking at. Some of the radiators on the ground floor...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
I would like to add an additional radiator to our central heating system. We have an attached double garage converted to a man-cave and workshop...
