Discuss Adding a secondary return to a system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Hi, what do people a think is the best way to add a secondary return to an unvented cylinder install.
The scenario is I am quoting to replace a gravity system with an unvented. The bathroom furthest away takes around 2 minutes to get hot water. The problem is all the floors are glued and screwed tongue and groove chipboard so not easy to take up and run the return.
Cheers
Really? We've just done a new build with about 90% plastic. It was installed with a secondary return. Which manufacturer, the pump or cylinder manufacturer?
Owch, the get the towels ready.
All the plastic manufactures. Circulating return has to be copper then the branches have to be 1 metre in copper then can go to plastic.
The pipe manufacturer.
I worked for a company that did the hot water in plastic and the return in copper. They seemed to think that was ok.
Reply to Adding a secondary return to a system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
