Adding additional radiator
View the thread, titled "Adding additional radiator" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi
I've got a Worcester Bosch combi boiler in the far corner of my attached garage, pipe run approx 4 metres through garage loft and into the house and start of radiator circuit, I would like to put a radiator in the garage near the boiler, my question is can I just T off the heating pipes near the boiler and just add a rad ? I'm sure i read somewhere that putting a rad in so near boiler and so far from the house rads will affect the circuit ? any advice would be much appreciated.
As long as it's sized and piped correctly and the system is balanced it shouldn't be a problem
As in a normal garage, not been converted to a bedroom? Why bother with the heat your going to loose it doesn`t make sense.
Has your system got any zones controlled by wall stats?
That could override the heating side if the indoors stat(s) temperature is satisfied and prevent the garage rad heating at times
Other than that, it is okay to have the radiator, but the garage will be a massive heat loss unless it is well insulated into a room.
The balance of the system could be badly affected by adding the radiator if the rad was left full flow
Hmm... I think you'll be disappointed. People use radiant heaters in workshops because the radiation can be selectively aimed at the people in the work area, which uses a lot less power than trying to heat the whole space. The losses from from a garage / workshop are normally huge because they are rarely insulated.
Reply to the thread, titled "Adding additional radiator" which is posted in UK Plumbers Forums on Plumbers Forums.
Danman,
Chuck,
