- Messages
- 56
Hello I would like to add a radiator to my current heating system and would like to take some advice on how to achieve this?
Discuss Adding new radiator to heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Your questions have gone beyond guidance. Best of luck with it.Not at all, this is why I joined this forum
Some guidance and I will have it sorted.
My first hour's £45.00, but not a bad idea otherwise. The OP seems to be researching how a heating system is plumbed and may be able to work out if it's S plan or Y plan (or C, W, etc plan), but some people are able to look at a mess of pipework and make sense of it and others really struggle. But obviously it's easier to identify if you do this every day.Ian it may be wise to phone a local plumber and explain what you want to do, pay him £30 to come and look at your system and point you in the right direction.
I have done this for people in the past, I like it when people try to help themselves rather than just get someone in for every little job.
Then you have someone who’s seen it on your side if you get stuck ( no reason you will), and if the worst comes to the worst they can sort it for you.
Good luck
Both pipes are cold when hot water is called for, so are these part of the central heating circuit?Does said pipes get hot when the hot water is on ?
Are you Plumbing only?My first hour's £45.00, but not a bad idea otherwise. The OP seems to be researching how a heating system is plumbed and may be able to work out if it's S plan or Y plan (or C, W, etc plan), but some people are able to look at a mess of pipework and make sense of it and others really struggle. But obviously it's easier to identify if you do this every day.
Are you sure they are heating pipes and not water. Where are your port valve/s? Near tank or pump? Brass body with a wee box on top. This will give you a better idea.
That’s good least you know now
Reply to Adding new radiator to heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
