Discuss Advantage unvented cylinders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
quality
Anyone got any pro`s or cons on the above from williams?
Fitted 8 this year on new builds.
Pros.
Stainless steel . Good combi valve, with separate balanced cold. Good bracket on the ex vessel. Great price.
Cons. The coil isn’t as high recovery as others. Tprv comes fitted, but is always loose!
Other than that, I’ve had no problems. I think they are made by RM
Reply to Advantage unvented cylinders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form...
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
Did anyone watch Britain's Got Talent last night? There was a Plumber on from Stockport called Darren who bottled it last year but did his...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
