Discuss Advice about twin coils in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jimgiraffe
Hi
Just got a twin coil cylinder, for an unvented system, do i need to connect in the solar coil before using the cylinder or can I do it at a later date???
Cheers
jimgiraffe
Can connect it whenever you want. Customer had new boiler and unvented cylinder with twin coils as wanted solar thermal. Couldn't affor it all at once so the boiler was changed and twin coil cylinder installed. Solar to be added at a later date.
Reply to Advice about twin coils in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future...
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
After some advice, i have recently had solar panels fitted and have an Eddi which uses the energy we generate to heat the cylinder using the...
Hi, I was hoping to replace an old system boiler with a Vaillant Ecotec Exclusive 627 system boiler, thats the one with the diverter valve so no...
Hello! I have a new Vaillant boiler being installed and will install a new cylinder at the same time. Our installer is recommending a UK Cylinders...
1K
