Discuss Advice needed - Unvented cylinder - Normal or not normal? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jimi
Hello,
Having recently bought a new property which has an unvented hot water system installed, I'm just trying to understand what's normal and what's not so normal having had no experience of an unvented system in any of my previous properties.
My intrigue/concern really comes from when the boiler should be off, I.E. according to how I've programmed the timings on the boiler control unit there should be nothing calling for heat; thermostat's (one upstairs one down stairs) set to 15c and the hot water should not be on.
However, when this is the case, I'm experiencing the Wilo Yonos Para pump located on the cylinder start up every 5 minutes or so. When this happens I can see the LED on the pump control is a continuous green and I can hear the pump whirring away. This will continue for a minute or so after which the pump will turn itself off (LED is then un-lit and no noise). In conjunction with this, every 10 - 15 minutes the boiler will also ignite, even though there should be nothing calling for heat.
Is this normal operation for the boiler/cylinder to act in this way or not?
many thanks,
Depends is any of the programs on when this happens hot water or heating
Sounds like something is calling for heat
Hi
Sounds like you have a thermal store..
Could you pop a picture on here?
Hi
Pic attached.
There should be nothing calling for heat. Water heating should be off and thermostats set well below actual room temps
So none of the 3 zones on the timer are on / calling for heat ?
No. None of the 3 zones should be calling for heat when this is occurring. Timer control unit is set to switch the system to "off" at 11pm and at the same time each of the two thermostats set themselves to 15c.
From my understanding there should be nothing calling for heat until 6am the next morning when the timer control unit is set to switch the system back on and the two thermostats set themselves at 20c.
However, as said above, at this point (post 11pm) I can hear the pump on the cylinder continuing to operate every 5 minutes or so with the boiler igniting every 10 minutes or so continuously throughout the night.
Same things happens if I override the timer programs and manually switch the timer control unit to "off".
sounds like you need a heating engy just to check a few things might be wired wrong as, if your certain everything is off
upstairs zone
downstairs zone
and hot water
its not suppose to run, you might have a bad time clock also
upstairs zone
downstairs zone
and hot water
Thanks for info. It's a new build property so I'll report it to the house builder for their engineer/electrician to look in to
you might have a sticky motorised valve ,
if it is a new build someone doesnt know there white from their grey wires by the sounds of things
Wouldn't surprise me in the slightest to be honest. We've had other issues where circuits have been wired incorrectly!
Reply to Advice needed - Unvented cylinder - Normal or not normal? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
