A
ASJ
Hello I'm new on here so apologise if this has already been covered but couldn't find anything on the search.
I am looking for some advice on ballancing a single pipe central heating system. My question is should i be striving to achieve the 11 degC temperature drop accross each radiator, as you would do with a 2 pipe system pipe system, or should i just try to get them all as close to the same temperature as possible?
Also the upstairs loop is tee'd off the downstairs loop but has a gate valve on the return pipe before it feeds back into the downstairs loop. what would this be for? Is this something to do with the ballancing the upstairs loop?
Many thanks.
Many thanks.
