Discuss Advice on faulty water underfloor heating system in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello all and hope everyone is well,
New to the forum and would be very grateful for any expert help.
I live in a small flat that has underfloor heating zones in living, bedroom and bathroom.
Unfortunately, the floor no longer heats up when I activate the bedroom and living room zones. However, oddly, the heated towel rail in the bathroom gets extremely hot, like all of the systems efforts are going to it.
I have attached some photographs showing the underfloor heating system set up. I have a valliant eco tec pro combi boiler, and the UFH system is by Heatmiser.
Each thermostat is correctly paired with the wireless receiver, however I did have an issue with some faulty batteries in each thermostat that required me to re-pair each thermostat to the receiver. This was quite a while ago and i couldn’t say if this is when the general system stopped working.
Any help would be hugely appreciated. Would be excellent if I could fix the issue myself although happy to get an expert in if required.
Many thanks.
Dylan
From off take a picture of the flow meters eg with no zone calling
Turn one zone on and do you see the flow meter move down ? Test the other zones the same
Hi Shaun,
Thank you very much for the quick response.
I attach photographs labelled as:
no zone calling
zone 1
zone 2
zone 3
I let each zone heat up for around 5 minutes before taking the photographs.
and then waited a couple of minutes before putting another zone on.
hope the photos are clear and thank you in advance for any input you can provide.
Dylan
I suspect zone 1 and 3 are linked maybe a big room
2 is an independent zone
All looks to be working tbh and with the manifold moving 80 heat the floor should warm up might take a day to fully warm up
Reply to Advice on faulty water underfloor heating system in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, gotta a bit of an issue with refilling my underfloor heating. Am I right in saying that the flow meters along the manifold should be on the...
I have had a problem where 2 downstair radiators are not heating up the same as the rest of the radiators around the house, now previously i had...
Hello, I have a gas boiler in my apartment that heats a net area of 300 m2 with an underfloor heating system. The boiler has a capacity of 45 kW...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
I need to extend my central heating from my newly built extension in to the old part of my house. I need to feed 3 rads in separate bedrooms on...
