Discuss Advice on Thermostatic Mixer Tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Kevin Shulver
I am thinking about replacing my standard Bath/Shower mixer with a Thermostatic one, however I am a bit put off and confused by the talk about different pressures. I live in a first floor flat with one flat above me, my bathroom cold water is fed from a communal tank on the roof which must be about 6 meters above my bath,the hot water is fed from a combi boiler. Can anyone advise me if fitting a Thermostatic Mixer would cause me any problems. I have service valves in place so shutting off the supplies isn't a problem, my problem is whether the valve would function correctly.
Many Thanks
The Aqualisa Midas 300 for HP/Combi should be able to handle that but why not ring Aqualisa Technical for confirmation
Depends on the pressure of the gravity. Some flats with cold tanks in the roof have better pressure and flow than the mains. Still suggest he gives Aqualisa a ring. They will sort him out. The 300 is valves for HP as well
Reply to Advice on Thermostatic Mixer Tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
I will be taking out my bath and putting a shower tray in. Under the bath there is a thermostatic mixer valve, I can't see ATM but pretty sure...
Got intermittent hot water coming the from a combi boiler to kitchen mixer tap when it hits the T junction for the upstairs bath it's hot, but on...
V
Hi All, Hope all are doing great. I have replaced two separate tap of my bathtub by mixer tap with thermostat. Previous with two separate tabs...
Deleted member 120897
