Discuss Advice on which flexi connector i need? in the DIY Plumbing Forum area at PlumbersForums.net
Hi all.
I need a flexible connector to connect my overflow waste to the main waste. The standard overflow pipes works for 1 end (this is to the main waste and is screwed on). However the end to the actual overflow bit is not big enough to fit over it. The original pipe's end was stretchy so it could fit over it but i can't find the same pipe anywhere?
This pic belows are without the pipe and the other is with the original pipe attached that i now need.
Hi all.
This pic belows are without the pipe and the other is with the original pipe attached that i now need. View attachment 48279
Just to add that the pipe fits over the top end (it is quite stretchy). It's not clear from the pic as it looks like it just goes into it.
There a pain normally remove them from the top eg overflow and do them out in front of you also use a small amount of washing up liquid on the inside of the flex
Correct dismantle the overflow part so you have more access
Reply to Advice on which flexi connector i need? in the DIY Plumbing Forum area at PlumbersForums.net
