Discuss air problem with Worcester life 8000 regular in the Central Heating Forum area at PlumbersForums.net
Has anyone had any experience with the drain off/bleed valve on the primary return ,adjacent too main heat exchanger on Worcester life 8000 (45kw) regular ?
I want too replace the 3/8 threaded drain off /bleed valve with a AAV ,has anymore does this?
large system 28 rads 3 floors ,sealed system
thanks
Why are you having air problems?
Reply to air problem with Worcester life 8000 regular in the Central Heating Forum area at PlumbersForums.net
