Discuss Air switch leaking on whirlpool bath in the USA area at PlumbersForums.net
Hi, I have a Spa/Whirlpool bath and the on/off switch is letting water in from the top of the chrome switch. There is only a slight gap as can be seen in the first picture, but when showering, water gets into the switch and then comes out of the two small holes in the bottom of the switch, as can be seen in picture 2 and onto my bathroom floor. I cannot for the life of me think how to solve the problem. I thought of putting sealant into the two small holes and blocking them, but ii looks like they are there to prevent water getting into the air pipe, which attaches to the bottom. If anyone has any ideas, I would be most grateful. I have also attached a picture of the inside of the switch.
Kind regards, Kev.
They look like they are there for the purpose that you are complying about if the weren’t then the button would just fill with water
cover it with something like an upturned dish or cling film other than that no contact whirlpool see if there is a different switch
Reply to Air switch leaking on whirlpool bath in the USA area at PlumbersForums.net
Good morning! First post looking for advice on an issue I am having with a bath installation. Although I have installed many baths before, mainly...
Hi all. Shower is leaking into downstairs when water is being aimed at wall . All sealant has been redone on outside and between shower tray and...
Hi I have these air jets in the base of my bath and when I switch the pump on only one works, it started working and lots of grime came out so I...
1K
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards...
Hi all, I would really appreciate your eyes on these pictures - What do you see ? Does anything look strange about the Rockwool insulation to...
